Solid Wood Machining
Invicta Ti-14 spindle
8/12/24
Steve Pueschel Member
Website: https://www.alliancemachinery.com
We have a customer with an Invicta Ti14 shaper and having difficulty removing the 1 1/4" spindle. Anyone out there have this machine with some suggestions? A 2' breaker bar and penetrating oil won't release the lower locking nut. Could it be reverse thread?
View higher quality, full size image (1280 X 1030)
View higher quality, full size image (1280 X 1280)
https://pearl-hifi.com/06_Lit_Archive/15_Mfrs_Publications/01_Wood_Working/Invicta/TI-14_Spindle_Shaper/Invicta%20TI-14%20V.05%20Sliding%20Tilting%20Shaper.pdf
8/14/24       #2: Invicta Ti-14 spindle ...
BH Davis  Member
That looks a lot like the SCMI T-110 spindle setup. When the spindle wouldn't release on my old T-110 I'd put a large cutter head onto the spindle with no spacers above or below it. Then I'd thread the nut on the top of the spindle.
With no spacers in place the cutter head can slide up and down on the spindle shaft.
A few good upward strokes of the cutter head against the bottom of the nut would jar the taper loose.
Careful trying to force that large clamping nut to turn. It's likely got a double thread. Large for pull down and smaller for locking the taper. Strange setup.....I never liked it. If the taper fit is still tight forcing the nut can force the spindle to turn while the spindle base is locked in place. This can cause gouging of the tapered surfaces that could require dismantling everything and having a machine shop repair the tapers.
8/20/24       #3: Invicta Ti-14 spindle ...
Ryan Member
Your spindles look different than mine. It is indeed right hand thread. If it was not properly installed they can be a bear to remove.
8/20/24       #4: Invicta Ti-14 spindle ...
Ryan Member
This is from the manual.
9/5/25       #5: Invicta Ti-14 spindle ...
Mrfee
I had to take my whole spindle assembly out to a machine shop to remove, they had to make a custom jig to do it. I’m glad I didn’t see how they did it because I assume it was aggressive
