Solid Wood Machining
Screw for molder head insert
12/5/24
duster
I'm trying to find replacement screws for the inserts on one of my molder heads. A couple screws were damaged by making contact with a feed wheel. The screws are M6 x 15mm long, witha 9 mm flat head. I've done an extensive search and have only been able to find screws with a 12mm head, which is too big and sits proud of the insert by a few mm. The screw on the left is what I need, the one on the right is the only size I've been able to find. Any ideas on where I might find these?
View higher quality, full size image (640 X 626)
12/6/24       #3: Screw for molder head insert ...
Dustin Orth
Call Global tooling in Oregon. They should be able to get you the right one, buy extras when you find the right one.
12/6/24       #4: Screw for molder head insert ...
duster
Thanks Dustin, I'll give them a call. I've bought carbide inserts from them before, didn't think to try them for the screws.
