Solid Wood Machining
Bench grinder bristle wheels for wood (not steel)
12/9/24
VermonterDad Member
Website: http://lackley.com
Hi,
I am making a run of frame saw handles that are almost 20" long with roundovers along most of the length. I would like to find an abrasive bristle wheel product for my baldor bench grinder that would allow me to remove the cnc mill marks and get those roundovers to like 220 quickly without all that hand sanding. any suggestions for products? i think the wheels are like 8" diameter
12/10/24       #2: Bench grinder bristle wheels for wo ...
BH Davis  Member
Search for Star Sanders from Rockler and other sources. They are individual layers that could possibly be slid onto your grinder shaft.
Also lots of other drill mounted options exist that you can experiment with to find out what works best. Then once you know what works you can look for a similar product for the bench grinder.
12/10/24       #3: Bench grinder bristle wheels for wo ...
VermonterDad Member
Thanks BH I checked out that product and it looks like the sanding stars would be helpful in a lot of instances but I'm looking for more of a filament-based product like coated bristles or very thin strips that would tend to ride over a profile rather than shape it...like this product from dedeco:
https://www.amazon.com/Dedeco-Sunburst-Industrial-Thermoplastic-Polishi
ng/dp/B07N2DSFW9
the dedeco looks promising but the arbor size is wrong and the dang thing is 50 bucks.
I appreciate the suggestion👍
12/10/24       #4: Bench grinder bristle wheels for wo ...
Rocketdc
You're looking for flap wheels for wood, they're strands of abrasive, different from flap wheels for metal.
Quickwood and flex trim USA are two companies that sell them, but if you think $50 is too much I don't believe they'll have any products in your price range.
12/12/24       #5: Bench grinder bristle wheels for wo ...
Mark Member
https://www.sand-rite.com
1/7/25       #6: Bench grinder bristle wheels for wo ...
neelaadri trueframe Member
Website: http://www.trueframe.in
Bench grinder bristle wheels designed for wood are perfect for smoothing, shaping, and cleaning wooden surfaces without causing damage. These specialized wheels provide a gentle touch, ideal for stripping old finishes or polishing intricate details. Unlike steel bristles, they prevent scratches, making them a must-have tool for woodworkers seeking precision and a flawless finish on their projects.
