Solid Wood Machining
Weinig powermat 1200
1/2/25
Marty Levin Member
We have a Weinig 1200 6 head moulder. Problem being that the #6 bottom isn’t straight. I can set the straight edge against the fence and just tick it with the cutter and on the outside of a 6” straight head it lifts the straight edge up by 6 thousandths. Was wondering if anyone else has seen this and if anyone has a possible solution. Thanks.
1/2/25       #2: Weinig powermat 1200 ...
Dustin Orth
Have you taken the bed plates off and checked that something isn't under them? I would also check all the bolts that mount the spindle to the main casting and make sure something didn't come loose. That would be my starting point.
1/5/25       #3: Weinig powermat 1200 ...
Rob Scaffe  Member
Assuming you have checked the table plates, More than likely it is the slide. You can check the tension of the nuts at the top of the gib, but probably there is debris, or worse, galling between the slide and the main casting. The slide will need to be removed and cleaned /galling removed to correct this.
1/5/25       #4: Weinig powermat 1200 ...
Rob Scaffe  Member
By the way, don't overlook the obvious, I am assuming you have checked your knives to verify they are ground straight in the cutter head.
1/9/25       #5: Weinig powermat 1200 ...
Marty Levin Member
Thank you for the response. I did remove and clean under the bed plates and did a bolt check. My next step is to remove and clean the slide as you said. Looks to be a not so easy process. Thanks again.
