Solid Wood Machining
Powermat
3/5/25
Rick
We run a powermat and the spindle seems to jump up after we set it and turn it on. The same thing happens for the inside head. What is the issue and has anyone else dealt with this. This isn't the first time I ran into this issue. I also had the issue on a Unimat 1000 that I ran in Chicago. Please help me get to the bottom of the issue. Thank you
3/12/25       #2: Powermat ...
The Weinigs and other moulders I am familiar with all have locks that are loosened to adjust spindle height, then tightened after adjustment. This locks down the spindle carriage, preventing any movement.
Please confirm this is what you see.
It is possible that the motor is loose in the carriage, but then there would be other defects immediately.
The fact you have seen this on other machines makes me think it is something you are doing/not doing correctly.
