Solid Wood Machining
50’s 16” Yates American jointer
4/21/25
Dave Mayer
Website: http://MC3 millworks
How do I set spring joint lever. Having trouble getting a straight joint. I don’t want a spring joint.
4/23/25       #3: 50’s 16” Yates American jointer ...
Dustin Orth
I had a Northfield that had that same ability. The infeed and outfeed tables must be parallel with each other to avoid spring joints. I used a long straight edge and set the infeed at 0. Then set the straight edge on the out feed and bridge to the infeed. Adjust the outfeed table until its perfect with the infeed. Then check the cutterhead to make sure its lined up with the outfeed table. Don't forget to check at the left side and right side of the cutterhead to make sure the tables are not set at a twist. Hope this helps.
4/30/25       #6: 50’s 16” Yates American jointer ...
BH Davis  Member
As long as the tables are true to one another as explained above the next most important setup detail is cutter head to outfeed table alignment. The top of the cutters MUST be both perfectly parallel to the width of the outfeed table and perfectly even with the outfeed table surface when at the high point of the cutting arc.
You need to set the knives so they are parallel with the table surface. Then you need to adjust the height of the outfeed table to match the high point of the knife swing.
If the outfeed table is lower than the cutter head high point you will not get a straight cut.
If the outfeed table is higher than the cutter head high point the lead end of your board will butt into the end of the outfeed table.
In my opinion the two most difficult machines to set up properly in the average woodshop are the band saw and the jointer. Both need to be in correct alignment in order to work correctly.
