Solid Wood Machining
SCM shaper spindle swap
7/16/25
I just purchased an SCM T160a tilt head shaper circa 2010. The spindle is 30mm and I have some custom tooling that is 1 1/4" bore. I checked with SCM and they do not even recognize the part number from the T160 parts list for the 1 1/4" spindle.
My question is: I have found a listing for a T110 spindle on ebay with what looks like the correct taper and mount nut. Does anyone have experience with interchangability of SCM spindles across model numbers?
What other alternatives do you suggest. I have two matched heads that are what I need to be run on the new shaper. I could have them bored and sleeved to 30mm.
Any other suggestions? Thanks.
