Solid Wood Machining
Weinig Optiut 350 freezing up mid cycle
7/22/25
Zach Member
Hey everyone,
We have been having a strange issue with our Weinig Opticut 350 that I can't seem to figure out.
As you can see in this video, while the machine is in the middle of cutting a board, it will suddenly freeze up and make this buzzing noise. I cannot seem to find any obvious reason that this is happening, and for some reason opening and closing the door will immediately fix it.
While it's not something I encourage, one of my crew members also discovered that when we are running longer stock, lifting the back of the board even just a bit will fix the issue as well.
The only factor that I can think of as to why opening the door fixes the issue is possibly that it is causing the roller wheels to raise up and come back down, suggesting that it is possibly an issue with the roller wheels. But as I said, I'm really not sure. We've looked at this machine in every aspect we are capable of and cannot find any clear cause for why this is happening.
If anyone has any suggestions as to how we can fix this, it would be greatly appreciated. This is hurting our production significantly.
Thank you!
Opticut Video
8/2/25       #2: Weinig Optiut 350 freezing up mid c ...
BH Davis  Member
What happens if you crack the door while it is running. Do you get the same result? If so then look at the door interlock switch and wiring.
Just a thought.
