Solid Wood Machining
Saw blade I.D.
9/24/25
Jason
I was wondering if anyone knows what this blade is used for? 12” dia, 60 tooth. The blade is 1/2” thick! 1-1/4”bore. I have never seen one of these. 4 of the 60 teeth are on the opposite edge of the disk.
9/25/25       #3: Saw blade I.D. ...
Dustin Orth
Maybe a hogger blade on a big ripsaw? Does it have any pin holes or keyways in the bore?
9/25/25       #4: Saw blade I.D. ...
Jason
Nope, just a plain round bore. There are 3 deep dimples near the rim that I assume are for balancing.
10/15/25       #5: Saw blade I.D. ...
You sure it's for wood?
10/15/25       #6: Saw blade I.D. ...
Jason
Not sure what it was used for. There is 3 of them and they all have the rubbery dipped stuff on the edge from just having been sharpened. No pitch build up or any sign of what they were cutting.
10/15/25       #7: Saw blade I.D. ...
The geometry doesn't look like it's for wood. Maybe a metal grooving bit for aluminum. Just surprised at it's diameter if it's designed for metal. Unless it's a deep slotter.
10/28/25       #8: Saw blade I.D. ...
NJ Furniture Mart  Member
Website: https://www.njfurnituremart.com/
Likely a laminate-scoring combination blade, 60T finish teeth plus reverse scoring teeth for tear-free panel cuts; ½″ thick for rigidity.
