Solid Wood Machining
Hydrolock moulder heads
10/21/25
tsuther Member
Can someone explain the hydrolock moulder head please. The ones I've seen have 2 grease fittings on both ends of the head. Do you put grease in both of the outside grease fittings or just 1 ? I cant find anything explaining how its setup on a moulder.
10/23/25       #3: Hydrolock moulder heads ...
Jason
Each end should have a grease fitting and a pressure relief fitting. Depending on what spindle you use the head on there will always be fittings exposed.
