Solid Wood Machining
6 head moulder - big ripples
12/9/25
Alan Barr
Hi everyone! Hoping you can help! I’ve been working with a wadkin 6 head moulder since march as a complete novice, with relative success until this morning! The bar is producing big ripples across the top and below every inch or so. Please see photo! I have tried all I can think of but nothing is fixing the issue. Any ideas? Thanks, Alan
12/9/25       #2: 6 head moulder - big ripples ...
Dustin Orth  Member
Looks very evenly spaced about every inch or so? Need to check the spindle bearings, spacing is wrong for a feed roll being out of whack. Are you getting jambs along with the marks?
12/9/25       #3: 6 head moulder - big ripples ...
Alan Barr
Hi Dustin,
No Jambs, however I was doing some tests this afternoon and can hear a "dulling" or "wer down" noise every so often but doesnt seem to be in any rythem so thought it might be a belt issue. I will check the bearings and see how were doing there.
I have looked at some other profiles ran at the same time and it is severe on some and minimal on others, im lost!
12/9/25       #4: 6 head moulder - big ripples ...
Dustin Orth
Yes on checking the belts but I would pull them off and free spin the spindles. If they don't sound smooth or stop fairly quick, it's bearings. You may have to spin them quite a bit to hear a clunk in the bearing but that can be heard if you have a stethoscope or similar.
12/11/25       #5: 6 head moulder - big ripples ...
David R Sochar
You can contact Weinig to attend their classes on molder training. Different makes, but the principles are the same. Or have a trainer come to your shop and train your staff.
Diagnose and process are hard to do in an online environment.
12/11/25       #6: 6 head moulder - big ripples ...
Jason
Alan, I have had a dull top head give me this showing up on the last bottom finish. Not a ripple that I could feel but that same pattern evenly spaced like that. My advice before tearing too much apart is sharpen all 4 horizontal heads. If you’re not needing your 1st top then just keep that one up out of the way. Dull tooling can effect the feed enough to give some head scratching finishes.
1/14/26       #7: 6 head moulder - big ripples ...
Dustin Orth  Member
Did you get it figured out? What was the problem?
1/14/26       #8: 6 head moulder - big ripples ...
Alex_Zhang Member
Dear Alan,
Dustin and Jason have pointed out two crucial areas: spindle bearings and tool sharpening. Regularly spaced ripples often indicate periodic vibrations in rotating components.
Based on your description (evenly spaced, no material jamming, sometimes accompanied by unusual noises), I suggest you investigate both of these points simultaneously:
Spindle radial runout: As Dustin suggested, remove the belt and manually rotate each spindle quickly. Feel for any "sticking" or uneven resistance; this is more direct than simply listening to the sound. Even slight runout will be amplified at high speeds.
Tool condition: Jason's reminder is very relevant. Please specifically check the horizontal cutter heads near the material exit. Even a tiny chip in a tool can create a regular impact with each rotation, leading to the ripples.
Troubleshooting order: You can prioritize spending 10 minutes visually inspecting and feeling the edges of all the horizontal cutter heads for any obvious damage. If there is none, then the bearing issue becomes more likely.
I hope you can find the root cause soon. If you solve it, I look forward to you sharing the final solution; this would be valuable experience for the community.
