Solid Wood Machining
Grinding Angle for Larch
8/28/25
Gerhard Pillichshammer Member
Can somebody help me with getting the right Grinding angle for Larch
I Ran around 1200 feet of Larch and the knive edge went really dull
I set the Grinding angle at 26 degrees at my Rondamat 931
And i am using 20° hook
View higher quality, full size image (3072 X 4080)
View higher quality, full size image (4080 X 3072)
12/2/25       #2: Grinding Angle for Larch ...
MattDav15 Member
Larch is pretty abrasive, so it's not unusual for knives to dull faster than expected. A 26° grinding angle with a 20° hook is on the sharper side, which gives a clean cut but reduces durability. Many people bump the angle up to 28–30° for larch to get better edge life, even if the cut becomes slightly less smooth.
1/27/26       #3: Grinding Angle for Larch ...
JamesS53 Member
Website: https://trinityrental.com/rent-cadillac
Larch can be surprisingly abrasive, especially if it’s dry or has a lot of resin and silica — so faster edge wear isn’t unusual. A 26° grind is workable, but many people have better edge life on larch pushing that closer to 28–30°, even if you give up a bit of sharpness.
Your 20° hook is on the aggressive side for a species like larch. Dropping the hook slightly (closer to 15°) can reduce impact on the edge and help with longevity. Also worth checking resin buildup — larch will dull a knife fast if pitch starts cooking onto the edge.
