Solid Wood Machining
Knife grinding
10/10/23
Chris
Do knives need to be ground in a head that is the same hook angle as what will be run on the moulder? For example.. is it a problem to grind knives in a 20 degree pocket and then run them in a 12 deg?
10/11/23       #2: Knife grinding ...
David Rakauskas
Website: http://csaw.com/grinding
Yes and No. You can grind them in a different hook angle head if you compensate for it. For example on our P20CNC profile grinder you can grind in a zero degree dummy head and just tell the machine that the knives will be running on the molder in a 12 degree head and it will compensate. You can do similar with a manual grinder or by distorting the template when you make it.
So you either need to grind them in a head with the same hook angle (Easiest solution) or know what you're doing to compensate. Both work.
https://www.csaw.com/grinding-machinery/profile-grinders/utma-p20-cnc/
10/14/23       #3: Knife grinding ...
Henry
If you grind, at 20 degrees, a pattern that is .500" deep, then run those knives at 12 degrees the profile produced will be about .025" deeper.
Whether that becomes an issue or not depends on what you are making, and what kind of accuracy is required.
2/24/26       #4: Knife grinding ...
sarahwilson1 Member
I’d be cautious doing that. The hook angle affects how the knife presents to the wood, and grinding in a 20° pocket but running it in a 12° head can change the effective cutting geometry. You might end up with differences in chip load, cutting pressure, or even balance if the profile isn’t exactly where it should be relative to the head. It may “work,” but it’s not ideal — especially on higher-speed moulders.
