Solid Wood Machining
Gearbox lube for widebelt
11/9/23
duster
What would be the recommended lubricant for the gearbox of a variable speed widebelt sander? It's a 30 year old Tiawanese model, the manual doesn't say what to use. It looks like 90 weight gear oil, but it's hard to be sure.
11/10/23       #2: Gearbox lube for widebelt ...
SteveL
We just did this with our 30 year old timesaver. I used 90 weight gear oil. I don't know if it was the right stuff to use or not but that is what we went with.
I am now wondering what should be used in all the power feeders that are old and have never been changed.
11/10/23       #3: Gearbox lube for widebelt ...
duster
Thanks for reminding me about power feeders, I haven't ever changed the oil in the 4 I have.
11/10/23       #4: Gearbox lube for widebelt ...
BH Davis  Member
90w gear oil in the power feeders.
2/25/26       #5: Gearbox lube for widebelt ...
sarahwilson1 Member
On most of those older Taiwanese widebelts, 80W-90 gear oil is usually what they ran. If it looks and smells like gear oil and not something thinner like ATF or hydraulic oil, you’re probably in the right range. I’d stick with GL-4 if possible, just in case there’s any bronze in there. If you’re unsure, crack the drain and see what comes out — that’ll tell you pretty quick if it matches 80W-90 viscosity.
