Solid Wood Machining
using a molder as a 2 sided planer
12/22/23
CRIS
We are looking to streamline our drawer box side machining process. would a 5 head molder work for us. Mtl. is 15/16 in 5/8 out 12 in width max Looking to trim width to final size apply dado plane bottom plane top and add chamfer to 1 edge. Allowing for glue up mismatch we will be removing approximately 3/16 in from both top and bottom .My concerns are the holddowns kickback
12/22/23       #2: using a molder as a 2 sided planer ...
I've not been in big production shops, but do 5 head machines come with that kind of width capacity? The 5 head would not take out all the cup or twist of the stock.
12/22/23       #3: using a molder as a 2 sided planer ...
A moulder should give you some straightening ability on the first two heads. Not like a skilled operator and a jointer, but pretty good.
12/23/23       #4: using a molder as a 2 sided planer ...
Fred Frehner
Hi Cris,
We have a 12" Ledermac. Depending on the tooling in the outside head we can run up to 11 1/2" wide.
If we had raw stock that was not so flat we sometimes plane it oversized (in the Moulder) first to pre straiten it. Its an extra step but you can save a lot of material and get a much better straighter product.
12/23/23       #5: using a molder as a 2 sided planer ...
Dustin Orth
I use my molder all the time doing just this type of stuff, only out to around 9". Have you looked at the price of a 12" capacity molder? You would need to run a LOT of material to make it pay for itself. I just saw a used 12" 6 head machine for sale, around 85,000 if memory serves. That's a lot of drawer boxes. Anytime someone asks for 12" drawer stock, I run it old school because normally it's not a ton of lineal feet. The 3" up to 8" is usually hundreds of feet vs 20 or so per kitchen. Is the high cost of that 12" machine worth it? I would love one in my shop but it's rare that anything is over 9"
12/25/23       #7: using a molder as a 2 sided planer ...
Dave Edgerton  Member
A 5 head is the wrong machine for that kind of width. You need a top and bottom planer.
2/28/24       #8: using a molder as a 2 sided planer ...
David William  Member
A 5-head molder could streamline your drawer box side machining process, but ensure proper safety measures and consider kickback concerns with the holddowns.
2/27/26       #10: using a molder as a 2 sided planer ...
sarahwilson1 Member
A 5-head molder can handle that workflow, but setup will be everything. I’d try to keep material removal light per pass — if you’re taking close to 3/16" total off top and bottom, consider roughing first so the molder is just cleaning up. Heavy cuts are where kickback and lift usually start.
Strong, consistent holddowns and proper pressure shoe setup will matter a lot, especially at 5/8" final thickness. Make sure your feed rollers are dialed in and knives are sharp and well-balanced. I’d also run test pieces to dial sequencing — do your major surfacing and dado first, chamfer last so you’re not destabilizing the edge early.
