Solid Wood Machining
Power Feeder Tires advice
1/19/24
Kurt Member
Whats the best material for tires on a power feeder for feeding mostly dressed hardwood through a shaper? I see steff feeders come with 60 shore natural rubber. Mine currently has urethane tires but they seem to have gone hard, and are not holding well. If i go urethane what shore? Or is there benefits to rubber.
Thanks all!
1/19/24       #3: Power Feeder Tires advice ...
door shop guy
J&G machinery ask for Andy Shook
Blue rollers same width as stock steff tires. I forget the brand name.
I do not like western roller.
1/22/24       #4: Power Feeder Tires advice ...
Jim Herron
Western Roller yellow
Just replaced mine after 15 yrs of steady use
1/24/24       #5: Power Feeder Tires advice ...
Brent
Another vote for Western Roller from me, they were very helpful in getting me what I needed for an old Holz-Her feeder and another ancient Italian unit. Yellow is just fine and a decent compromise of hardness and grip IMO.
1/26/24       #6: Power Feeder Tires advice ...
Rodney Member
WESTERN ROLLER
2/27/26       #7: Power Feeder Tires advice ...
sarahwilson1 Member
For dressed hardwood on a shaper, most shops stick with natural rubber around 60 Shore A for a reason — it gives good grip without being overly aggressive, and it conforms slightly to minor surface variation. That balance usually means steadier feed pressure and less marking.
Urethane can last longer and resist wear better, but once it hardens (especially in cooler shops) it tends to lose grip. If you go urethane, many people prefer something in the 35–50 Shore A range for better traction, but it still won’t have quite the same “grab” as softer rubber.
