Solid Wood Machining
UNIQUE 313 MITER
2/5/26
JOHN ALLAN Member
Website: http://arkansawooddoors.com
Seeking resolution to eliminate tear out on face side profiles of our miter frame stock after being machined on our Unique 313. New inserts on heads, new drive on motor. Traditional flat surface frame stock runs fine. We have tried using painter tape pressed firmly into area of profile needing support with acceptable success. Checking other options if available.
3/19/26       #2: UNIQUE 313 MITER ...
lanyardschedule Member
We had the same issue on our 313. What helped us most: Light climb cut finish pass Add a tight backer block (more consistent than tape) Slightly slow feed speed Use shear inserts if possible Tape works, but backer support is more reliable long-term 👍
