Solid Wood Machining
S three S
4/10/26
Kirby Cole Member
I have a small shop and need to be able to S3S. What is the fastest, easiest way to accomplish this. I sell white oak lumber so a will be milling just white oak .
4/11/26       #2: S three S ...
Dustin Orth  Member
You need a straight line ripsaw and either a double sided planer or a molder to do it efficiently. It depends on how much quantity you are going to run. Just a little bit, those machines aren't worth it.
4/12/26       #3: S three S ...
Kirby Cole Member
Thanks, but can’t do that right now.
4/14/26       #4: S three S ...
Explain how you are doing it now, and where you would like to see improvements.
4/14/26       #5: S three S ...
Allen Chalifoux
I'd be interested in how your currently doing it now too and what your volumes are. Allen
4/14/26       #6: S three S ...
"Can't do it now" indicates a reluctance to consider all your options.
You have been given good suggestions, but are not interested in a dialogue.
Did one take too large a bite, one wonders....
4/14/26       #7: S three S ...
I also wonder if this is a predicament inquiry, or just looking for improvement question.
Getting in over our heads is what got most of us to where we are. So if that's the case, can't slight him there.
4/14/26       #8: S three S ...
Karl - Yes, you are right. I bit off more than I could chew more than once. Sweat and thinking smart kept me out of trouble.
I guess the difference is do you learn to take appropriate sized bites, or do you find ways to chew more efficiently?
4/14/26       #9: S three S ...
Dustin Orth  Member
Im willing to give advice from learning over the last 40 years, if someone doesn't want to listen, that's their choice.
