Solid Wood Machining
Tooling type for making crown on a shaper
5/19/26
SteveL Member
I have always just ordered the crown molding I need but am getting a little tired of lead time issues. I would like the ability to just make in house.
I only make cabinet doors with my shapers using insert heads from DIT, and that is about the limit of my experience with shaper tooling.
I'm wondering what recommendations anyone has for cutterheads for this, type and brand. I usually use 3-1/4" crown so would be aiming for something in that size range. These would be very short runs around 50ft at a time.
Would it be best to have two heads one for profile and one for the back angles?
5/19/26       #2: Tooling type for making crown on a ...
I would think you would be way better off anticipating your needs and stocking mouldings in house. A shaper is not really the correct machine fot the job. A moulder will give you straighter, smoother crown with less tear-out and sanding.
The other option is to find a supplier that keeps stock on hand and will deliver.
5/21/26       #3: Tooling type for making crown on a ...
Jon Member
Years ago I started making molding on a shaper with a corrugated head. We did it for a short time, but ultimately bought a small Shop Fox molder. It works really good for the short runs that we do. Set up is fairly easy and the machine is small so it doesn't use much floor space.
I know we do not make money making molding, but we have the ability to make any species at the quantity we need in a few hours.
