Solid Wood Machining
Sandingmaster CSB 2 900
6/30/26
C D Ernst Member
Website: http://www.renaissanceinwood.com
Does anyone know how to drop the heads or free up the conveyor up/ down? Sandingmaster CSC 2 900. I paid $95 for a manual on this series and NOTHING is the same in the manual as this machine. I installed a massive 3 phase converter and now I’m stuck.
Where there is usually an air release switch on the belt access end, there are only a pair of levers that don’t want to move. Help!
7/3/26       #3: Sandingmaster CSB 2 900 ...
Dustin Orth  Member
The 2 levers are to adjust the heads in relation to the thickness of the sanding belts and the hold down shoes. Not sure about why you don't have upper roller release switches. If you can find the air line feeding each one, you could add an air switch on the end. Automation Direct has those parts in stock. Until you do that, you could just shut air off to the machine to change belts. I have a little newer machine but a lot of the interior parts look similar.
7/4/26       #4: Sandingmaster CSB 2 900 ...
C D Ernst  Member
Thank you Dustin. Taking air off the machine doesn’t release the heads at all. It’s like they’re locked in place, super tight. Never seen anything like it.
7/4/26       #5: Sandingmaster CSB 2 900 ...
Dustin Orth  Member
Have you taken any of the pneumatic parts off and looked to see if they are contaminated? Rust from moisture might cause cylinders to lock up, or debris from a bad or no filter.
7/9/26       #6: Sandingmaster CSB 2 900 ...
visitorsmuth Member
Dustin, I am grateful. The caps are not released at all when the air is removed from the machine. It appears as though they are imprisoned in a super tight space. Nothing comparable to it has ever been observed.
