Solid Wood Machining
Minimax S 500P bandsaw catastrophic failure?
7/10/26
Door shop guy
My 20" Minimax year 2013 bandsaw was running a Woodmaster 1" carbide blade and the blade broke causing the upper door to be wedged shut and most of the blade raveled up inside the upper cabinet behind the wheel. Now the wheel wont raise or lower. I removed the door hinges and still cant get the door off. I haven't tried prying too hard yet. Something else broke I am sure. I ordered a scope to get in there to see. But I wanted to see if you guys could give a poor guy some advice. Much appreciated. Just counting my blessings that I am ok. Much appreciated.
7/11/26       #2: Minimax S 500P bandsaw catastrophic ...
Door shop guy
Well we were able to pry the door up and out which required a lot of force because the wheel jammed up so hard binding the door. Then we fished most of the blade out that was raveled up behind the wheel. The teeth were dug in so bad there were metal shavings that fell out. I inspected everything and luckily i had more blades in stock and the saw is up and running normally again. What a solid saw to be able to withstand the major impact and not have anything else broken. I am thankful!
