Value Added Wood Processing
How to make fine saw dust
8/16/09
Gamini chandrasekara Member
I need to know how to make fine saw dust ( mesh 80) out of normal saw dust. Can anyone explain it?
8/16/09       #2: How to make fine saw dust ...
cedarman
How much do you need? We have a good bit of cedar that is through a 25 mesh that would be good feed stock for further reduction to go through an 80 mesh screen.
8/16/09       #3: How to make fine saw dust ...
Gerald Ortman
The same sort of grinder that is used to grind corn. wheat or rice flour? May likely require either drying or moistening the sawdust feed stock to accomadate the process.
If you are making fuel for burning and need constant particle size for the injectors then carbonizing before grinding, which will also increase the btu value.
    • J&P Machines
    • CabMaster Software
    • Lignomat
