Value Added Wood Processing
Uses for Grade 3 & 4 Lumber
7/25/19
Leon
Hello all, I’m wondering what are grade three and four SPF lumber typically used for? They are unfit for actual structure building use correct?
7/25/19       #2: Uses for Grade 3 & 4 Lumber ...
Mark B
Crating material? If you have a demand for it bridge forms? Cut it into shims?
3/28/20       #4: Uses for Grade 3 & 4 Lumber ...
Sub lumber for furniture. The stuff that gets hidden like in an upholstered chair or couch. Usually you can get shorts between the knots.
12/7/22       #5: Uses for Grade 3 & 4 Lumber ...
Michael Member
SPF lumber tends to be used for single and multi-family home construction, commercial construction, crating and packaging
12/8/22       #6: Uses for Grade 3 & 4 Lumber ...
Marcken Member
Construction of single- and multi-family homes, commercial buildings, crating, and packaging typically use SPF lumber.
    • TradeJobPlacement.com
    • Cabnetware Support
    • Seam Mate
      Perfectly Aligned Countertop Seams with no Gaps
    • Woodwork Career Alliance
    • Limtech Industries, Inc.
