Value Added Wood Processing
UV Roll Coat Gloss
12/1/22
Geoffrey Member
I'm running the same product on two different roll coaters. Same gsm, same cure energy. I'm getting 25 gloss on one roll coater, and 51 on another. What should I be looking at to get 25 gloss on all applications?
12/7/22       #2: UV Roll Coat Gloss ...
Hamioa Member
RA1500 Premium Gloss Roller Coat Clear is a UV curable protective coating to maximize the durability and abrasion resistance of digitally printed graphics.
slope io
12/9/22       #3: UV Roll Coat Gloss ...
JeffA
UV products are heat sensitive. Roll coating particular. If you use the theory, higher heat lower gloss, lower heat higher gloss, you may find out why this is happening. When the bst, ( board surface temperature) or coating is high in temp, the gloss will be lower. And then the opposite is true, low bst higher gloss.
2/13/23       #4: UV Roll Coat Gloss ...
Mitch Suber Member
Are your applicator rollers identical? And are you able to apply the same thickness of product on both machines? Not sure these are the problem, but both could contribute.
4/12/23       #6: UV Roll Coat Gloss ...
mooaly Member
great
    • J&P Machines
    • CabMaster Software
    • Lignomat
