Value Added Wood Processing
Weinig 1200 6 head moulder
12/30/24
Marty Member
Hello. I have a question on our weinig 1200. On the #6 bottom it seems to be tipped. On a 6” or 9” straight head when straight knifed I can set to 0 on the inside agents the fence and on the outside it’s still like 6 thow high. Was wondering if theirs any adjustments I can make. Bed plates are new as well.
3/17/25       #3: Weinig 1200 6 head moulder ...
Dave Sochar
When Weinig techs train your people, things like this are covered thoroughly.
What do the Weinig phone techs have to say?
This appears to be another case of people suffering thru a complicated problem on their own, when help is not far away. This seems to be related to shops buying equipment with no one knowledgeable in house to operate it.
5/21/25       #6: Weinig 1200 6 head moulder ...
Troy
These problems are usually a simple fix. More often than not there is dirt, dust, a wood chip, or something under the bed plate. Could be the shim is dirty or even been bent, it ALL matters. A quick and easy check I use is the 12” scale that usually comes with the moulder happens to be .020”. Put a straight edge on the rear bed which likely has an .020 shim under it and see if you can slide the scale under the tip easily. Check both the inside and outside. I’m betting you find that it hits on one side. Next most common area is tooling. Check parallel on an opti. If your certain tooling is correct, and the bed is clean, the only other thing it could be is the dovetail slides. Could just simply be loose nuts. They’re supposed to be nylocks. Could be galling on the metal. Not an easy solution and pretty rare in comparison to the other more likely culprits. Most often this stemmed from abuse or lack of pm. Smart moneys on dirt under the bed plate.
