Veneer
Wet mil for PVA
6/16/22
Daniel Member
HI,
We have been hand rolling glue for so many years now and finally got into a glue spreader. My question is what is the recommended wet mil off a glue spreader for typical PVA glues. I have a call into the rep for our glue but thought this might give more opinions. Our typical layup is 1/8" MDF both sides of a 1-1/4" particle board core and in the hot press for 5 minutes at 90 deg..
Same process for many different wood species with a resawn "veneer" of 3mm thick but 60 deg. for 10 min.
Thanks.
6/18/22       #2: Wet mil for PVA ...
I can't give you the mil thickness number. I have never measured but I aim for a barely opaque glue film. I adjust for the absorbency of the substrate which I judge by any dull spots after rolling out. You will know if you have too much if you get bleed through. In my opinion more is not better it just introduces more moisture to the panel.
