Veneer
curved slab door
9/22/23
Jonathan Mahnken
I have one small 14"x22" curved slab door to make. what is the best way to vacuum press a bent lamination like this. I can make a form using my cnc machine...
9/22/23       #2: curved slab door ...
Will
Make a form. Put two layers of bending lauan on the form. Space the ribs close, you did not say the size of the door. Use a 1/4" lauan caul on front and back and squeeze. I assume there is veneer of some type hence the cauls.
9/22/23       #3: curved slab door ...
Jonathan Mahnken
Thanks, the door size is state above. the face and back veneer is maple. I'm trying to achieve approximately 3/4" thickness.
11/17/23       #5: curved slab door ...
BH Davis  Member
As said above two or three layers of bending Luan with your veneer on either side. If you have a wide belt sander use it to bring the entire sandwich down to 3/4". Put the maple veneer in the center of the sandwich and sand the bending Luan ply.
When you make your press form size the ribs so you can also have a layer of bending Luan on the face of the form.
11/28/23       #6: curved slab door ...
Jonathan Mahnken
Here's how its gone so far. A very large learning curve, but im satisfied with how it went. The luan was a little stiff, i think I would use something a little more flexible in the future
