Veneer
Veneer Technics
11/19/23
Burgh
I know there are various backings for veneer. 10mil, wood on wood and 3M PSA. I
also saw on ebay some veneer I liked called Raw wood veneer. Can someone tell me about this type? How do you apply it? I do not have a press. I saw some that looked interesting.
I am building a Stereo cabinet for my Fisher 400 Tube receiver. So there will be a little heat from the tubes. The power tubes are in the back and there is a cutout with screen for ventilation. Has anyone built one before and what wood would you suggest?
I was unsure if the PSA would hold up or what type of adhesive would be best.
I am also having a hard time finding veneer in smaller pieces 24" x 48". Everything else seems to be sold in large qty's. I don't want to piece it together as I have not done this before.
Thanks in Advance!
Fisher_400_Cabinet.pdf
11/21/23       #3: Veneer Technics ...
Will
Burg, this is a professional woodworking site. Your question leads me to believe this is not your profession.
The PSA is probably your best bet. It will hold up to the heat. It is unforgiving to apply, once it is stuck, it is stuck.
Good Luck,
