Veneer
Is this a balanced panel?
2/24/24
Tim Member
We often make veneered cabinet fronts with raw veneer on front and back on an MDF substrate. I’m wondering if anyone has insight as to wether or not we could use a paper backed veneer on the back (to save time) and the raw veneer on the front?
Does the paper backing count as a layer? I assume it would.
I was thinking of going about it like this. Paper backed veneer on the back, then paper backer such as GatorPly on the face, raw face veneer over that. This way both faces have the paper underlayment. Does anyone have experience making panels this way?
2/27/24       #3: Is this a balanced panel? ...
The MW Studio  Member
Website: themillworkstudio.com
Considering the requirement for the backer to be the same thickness as the face panel, you might want to explore alternatives that maintain uniformity. One option could be using a veneer with a paper backing that matches the thickness of your raw veneer on the front. This way, you achieve the desired consistency without compromising structural integrity.
2/28/24       #4: Is this a balanced panel? ...
tom gardiner
I have done this with good results. In my experience, if you are going to have issues with warping of veneered panels it will show itself in the shop in the first few days. How you handle to sheets after pressing is the most important ingredient to success.
2/28/24       #5: Is this a balanced panel? ...
Tim Member
Thanks for the replies. We’ll hot press at 90dg Celsius for 90 seconds and dead stack overnight while things cool. We’ll probably do a couple sessions of pressing in short order since we can’t do it all in one press cycle.
2/28/24       #6: Is this a balanced panel? ...
Tim Member
Ditto on the warped panels, they do tend to warp in a day or two if something is off.
2/28/24       #7: Is this a balanced panel? ...
Bozzy Member
Tim,
How thick is your raw veneer?
2/29/24       #8: Is this a balanced panel? ...
Tim Member
We haven’t purchased yet, but standard thickness .02”-.024”. Likely from Dooge or Certainly Wood.
3/9/24       #9: Is this a balanced panel? ...
I will say no, it is not a balanced panel. Same veneer two sides is the sure thing.
Are you a gambler?
If you are 8" x 8" panels you may be able to get away with the paper. But anything larger is risky.
3/9/24       #10: Is this a balanced panel? ...
Tim Member
David,
Both sides will be a walnut veneer of the same thickness. Only difference is one side is a purchased paper backed 4x8 sheet, while the other is raw veneer over a paper backer that we lay up in house.
Do you still think that’s too much of a gamble?
I appreciate the insight.
3/10/24       #11: Is this a balanced panel? ...
I understand the desire to save time (one pressing vs two?), but you are making what becomes a five ply panel. It does appear to be stable and balanced. Except for the fact that you will be adding two layers of glue to one side of the center, and only one layer of glue on the other side. And none of what you are adding is cross grain, to make a true plywood panel, and make it a stabl pand$
Again, if the panels are smaller and are well supported, that is different from large, and getting its flatness from some sort of trim.
I think I would take the safe route, and learn how to do a five ply glue up.
4/11/24       #12: Is this a balanced panel? ...
Jeff Member
Website: https://virmer.com/
A properly executed glue-up distributes adhesive evenly, maintaining balance and stability. Additionally, while cross-grain layers enhance stability in traditional plywood, alternative methods can achieve comparable results, especially in smaller, well-supported panels. Flexibility in approach can lead to efficient and effective outcomes without compromising quality.
4/11/24       #13: Is this a balanced panel? ...
Jeff - You should get a gig impersonating an AI computer.
Lots of words, and you said….what?
Yes, cross grain does make plywood stiffer - it is what makes plywood plywood. I an unsure what else you said, but I did recognize a few words.
Clarification of a less confabulatory nature would add to the conversation.
