Veneer
Pressing veneer longer than press
7/16/24
Chris Member
Looking for any tips when pressing veneer which is longer than our hydraulic press.
Currently planning to use PVA with heat, and to slide the panel after partially cured.
However we would prefer to keep using UF, which we use on all other veneering work; but I think this may cure too fast?
7/16/24       #2: Pressing veneer longer than press ...
tom gardiner
I slip press with PVA - 5 minutes at 60°C. No issues no telltale line of the first placement. Last time I used UF was years ago. We would get a line of cured glue bead that could be seen in the finished panel. I think sanding eliminated it.
Run a test on some strips to get your time and temperaturs right.
