Veneer
Veneer adhesive failure testing - cork substrate
9/10/24
Orin Zelenak
We've successfully veneered 1/4" cork (similar to standard corkboards) with rift white oak, raw flitch. The glued-up assembly was more flexible than using bending ply and worked for that particular application. The finished assembly was installed 2 years ago and hasn't changed.
We're now contemplating a new project and I want to test the glued-up assembly by:
1) bonding it to a rigid substrate which will (for all intents and purposes) not flex
2) cycle humidity from 30% to 100% repeatedly for a few days.
Does this seem like enough stress and of the right kind to test the assembly integrity? My concern is glueline failure. Could the veneer pull enough to delaminate from the glue line or could it rip away from the cork itself so the cork fails?
Any thoughts or suggestions for other test would be appreciated!
9/10/24       #2: Veneer adhesive failure testing - c ...
tom gardiner
I think your suggested test would be more than sufficient. The two failures that I would worry about would be wood to cork adhesion or cork to cork bond.
The cork will expand or compress easily to allow for the minor oak movement
Cool idea btw.
