Wood NetWork
Subject: Re: birds eyes
birds eyes
11/25/12
chettie Member
i'm getting birdseyes in random pieces. spraying precat oil base laq. over waterbase laq.. sand birdseyes off, clean with laq.thinner, naptha, and other cleaners, but they keep coming back. useing a turbin hvlp, and blowing off with an oil less comp. been useing this set-up for ten years. any help appreciated. thanks.
11/26/12       #2: birds eyes ...
C J Struthers  Member
Website: http://www.sorraiastudios.com
I've experienced the same thing now and again and it always comes down to contamination! Start at the gun and clean backwards till you've cleaned the entire spray system.
Then determine if there is anything else going on in your shop that might be putting contaminants into the air. Finally, check your sanding materials and solvents to make sure they are compatible with the lacquer you are using.
As I said in my case it has always come down to contamination, the hard part can be to determine from where!
Good luck,
CJ
    Excel Wood Products
