Wood NetWork
Subject: Re: Air Compressor Recommendations
9/13/15
Nick Christensen Member
Website: http://www.littlesaplingtoys.com
I am looking at two different types of compressors. All other things being equal our choice has come down to either a new reciprocating compressor or a Rotary Vane compressor (Champion LV series or similar) Does anyone have experience with a Rotary Vane compressor? The compressor is running about 40% of the day. We are using it for a few air sanders, and the tool changer for the cnc. Thanks!
9/23/15       #2: Air Compressor Recommendations ...
Edward Sierzenga Member
I have had several compressors for my shop all to run air tools dealing with and around woodworking.The air sanders eat air in volumes.All of mine are and have been standeard piston type and none of them could keep up for more than one user.My current unit is an 80 gallon 7.5hp. I had came into contact with rotary vane types when I was in the Air Force so I checked into one for my self. A compressor shop, a pro shop told me how much better they are, more air volume,quieter, cooler etc. Only problem was cost , I could not justify it for my one man shop. I am retired from servece and never wanted to get big. I have only seen them in high doller businesses I guess that's why Air Force could afford to use one. I have only heard good comments about them over 40+ years working with tools. Long answer I am sorry but if I was starting over I would get into a unit to use, especially if I needed volume. The newer sanders (air) use less than when I started but in a multi person shop I think in long run would be worth it unless as a hobby. One other consideration is if you have to rebuild one it is not as easy as cylinder type. I did rebuild a rotary vane pump in the service but I had very good tech data. It is do able just not as simple. I can't give you a cost my unit was about $3500.00 but costs have gone crazy I n last ten years. I hope this helps in some way.
5/8/16       #3: Air Compressor Recommendations ...
Irwin
If you are still in the market...look at Eaton Compressor. Phenomenal company and even better compressors. I have two of their compressors. A 15hp 120 gallon piston compressor (9yrs old) that literally runs every 15 min all day long and it Never misses a beat--I also have a 30hp rotary screw compressor (3yrs old) that is simply the best compressor I have ever owned.
    Excel Wood Products
