Wood NetWork
Subject: Re: scm k1000 edge bander
3/11/20
SEAN Member
Website: http://www.modularofficesystems.net
I am having trouble to get the machine to even run. No alarms, or codes. The belt is cleared. Press start and nothing. Glue is at operating temp as well. Even reset everything. The manuals are pretty vague for troubleshooting.
3/12/20       #2: scm k1000 edge bander ...
Start with your air supply. Have you got 100psi to the machine?
Open the electric cabinet. Is the VFD showing output?
Are you following the proper sequence of switches in the start procedure?
Is this machine new to you? Have you ever had it running? Have you seen it run?
3/12/20       #3: scm k1000 edge bander ...
SEAN Member
Thank you sir for responding. The machine is new to me 2006 scm k1000. I have 6 bars at the inlet hookup.
I do have power at the switch. I had to clear the track and that let the machine operate.
Now having issue with the glue pot and roller. I was pretty dirty so went ahead and took it apart and we are cleaning it. The glue what flow out like lava and coagulate and then just spill all over. I was not able to move the lever to control the flow was all gummed up.
I have also went through and cleaned all moving parts and made sure it is greased.
We had been doing all our edgebanding by hand mostly 3mm for worksurfaces pb just to hard when you get slammed with a 500 piece job!
3/13/20       #4: scm k1000 edge bander ...
On my SCM there is a fibreglass heat shield between the glue applicator body and the where the banding runs off the roll. It is removable to allow you to pre-heat the banding. It's primitive but works as long as you don't leave the banding there while the machine is idle. The heat will distort the banding.
Be careful of raising the heat. The glue has an upper limit and will begin to burn and lose adhesion.
If you can manage it make sure your substrate is room temperature. Cold boards will gel the glue and reduce the bond.
    Excel Wood Products
