Wood NetWork
Subject: Re: Moving a drum sander
4/6/22
vweaver Member
I got a great deal on a once-used Supermax
25-50 sander. I have to travel an hour to pick it up with my small 4x8 trailer. Suggestions on how to safely transport this 400# beast. I'm planning on lowering the drum onto a board to support the arm. But after that... Do I use ratchet straps or screw 2x4s all around it several boards deep? With the closed cabinet, not sure how to strap it. I've got until Saturday to figure it out. TIA
View higher quality, full size image (979 X 822)
4/9/22       #2: Moving a drum sander ...
MarkB
I'd just lower the head as you mentioned and either roll it up onto the trailer (if the mobility kit comes with it) if not I'd just bring a couple 2x's with a bevel cut on each end like a ski and rock it up, put one of the ski's under each edge, lag the machine to the ski, and drag it onto the trailer with a come along or brute force, whatever.
450lbs isnt anything to worry about. We moved a 9' tall 36" bandsaw that way, 2K lbs. Was gravy.
    Excel Wood Products
