Wood NetWork
Subject: Re: Reconstituted Veneers
1/4/24
Mike D  Member
Anyone using reconstituted sheet goods?
Looking at the possibility of trying some WhiteOak for some more consistent colour. You know, like most of those instagram/pinterest pictures everyone sees as perfect.
My question is how does it take a stain compared to a real WhiteOak product.
There's always the possibility on a job of having to create a custom component that requires solid material to coincide with the reconstituted panels.
thanks-Mike
1/4/24       #3: Reconstituted Veneers ...
Bruce H
I am using some on a project right now. Absolutely deluxe material. This project is black, I bought (reluctantly because it was $359.00.roll) matching 2mm edgeband and black glue for my edge bander. Turned out to be the right choice. I'll use fifteen sheets plus three rolls of banding.
1/5/24       #4: Reconstituted Veneers ...
The reconstituted rift white oak I worked with was made of white oak and it was excellent. I didn't stain it but I would assume that it would stain the same as natural.
1/12/24       #5: Reconstituted Veneers ...
Kevin Jenness
My former employer has used a lot of reconstituted veneer and it is very consistent. Staining is not a problem. If you want wooden wallpaper this stuff is the ticket.
1/12/24       #6: Reconstituted Veneers ...
The MW Studio Sponsor - The Millwork Studio
Website: themillworkstudio.com
Hey there! I've dabbled with reconstituted sheet goods, and they do have their perks, especially when aiming for that consistent color aesthetic you often see on Instagram and Pinterest. White Oak can be a great choice for achieving that look.
When it comes to staining, I've found that reconstituted panels tend to take stains quite well, and the consistency in color can make the overall finish look really polished. However, keep in mind that it might not absorb stain exactly the same way as solid White Oak. It's always a good idea to do a test on a small, inconspicuous area to see how it behaves with the specific stain you're planning to use.
And yeah, you bring up a valid point about the potential need for solid material in certain custom components. It's essential to consider the project requirements and ensure that you have the right balance of reconstituted panels and solid material to meet both aesthetic and functional needs.
5/19/24       #7: Reconstituted Veneers ...
Bruce H
I am on my second set of reconstituted veneer, this time Walnut. What these sheets allow is every one is the same color and grain pattern. It's not like a natural wood panel where you have to pick and choose what parts go where so they match. An interesting side note, the 2mm edge band is about $400.00 per 320' roll. I changed the glue color on my edgbander (Jowat brown) works very well.
    Excel Wood Products
