Wood NetWork
Subject: Re: Phase converter
Phase converter
7/19/25
Yankee11 Member
For an edgebander that is 3 phase with a PLC controller can I use a digital phase converter or do I need to use a rotary? I'm installing a 2014 Fravol 400-23 edgebander.
7/20/25       #2: Phase converter ...
BH Davis  Member
It is my experience that you just need to determine which 2 legs are feeding the PLC. Those two legs then are fed by your single phase 220v lines. The third leg from the static converter to the machine, the leg connected to the converter capacitors, goes only to the machine motor.
When the motor is up to speed and the capacitors have cut out of the circuit, your 220v single phase line then continues to spin the motor at 2/3 hp and feed full 220v to the PLC.
Only place this might be different is if the PLC is 110v instead of 220v. I think that would be very unusual as it means also running a neutral wire into the machine which simply isn't very logical from an electrical design standpoint.
8/6/25       #3: Phase converter ...
Bruce H
If you get a rotary converter other machines can be run with it where a digital converter typically runs only one machine.
8/28/25       #4: Phase converter ...
David William  Member
A digital phase converter is generally the better choice for CNC or PLC-controlled machines like your Fravol 400-23, since it provides cleaner, balanced power. Rotary converters may work, but digital ensures more reliability and avoids potential PLC faults.
    Excel Wood Products
