Wood NetWork
building a special router table
10/4/13
bill kenik Member
Can anyone help me?
I make baseball bats and every once in a while, someone wants the end cupped out.
I have a round nose bit that I've used in my drill with the bat clamped in a vise. I'm sure you can imagine it's impossible for me to keep the drill steady this way.
I've attached my idea for a special router table to hold the bat in place while using a plunge router to produce the cupped end.
I would like to have some type of swiveling action in the clamp to allow it to conform to the taper of the barrel and to allow tightening without turning.
Any thoughts or suggestions would be greatly appreciated.
I've included a very rough, not to scale sketch of my idea.
Thank you.
Bill Kenik
Router_Table_to_Cup_Bats.pdf
10/5/13       #2: building a special router table ...
ML
Hmm. Can't you just chuck it in your lathe? Seems to me that the quickest and most accurate way...
10/5/13       #3: building a special router table ...
bill kenik Member
Can you recommend a good centering device to hold the barrel in line with the drill bit?
10/16/13       #4: building a special router table ...
Jim Baldwin  Member
Website: http://www.handrailer.com
I can't imagine how you're making your baseball bats but the entire bat, including the cupped end, is typically turned on a lathe in one operation. The small, pencil-sized remaining center is carefully tipped off at the end. No separate router or drill press operation is required. I know of no other manufacturing procedure which would yield a perfectly concentric and balanced bat.
Any existing bat can likewise be modified on the lathe as well as refaced and refinished.
