Wood NetWork
Article about changing orbital back up pads
12/9/16
Adam West  Member
I just wrote this as it is a huge issue in the industry.
Most Overlooked Sanding Issue
The 5'' random orbital is an essential part of most wood working facilities. The tool allows rapid removal of material to create a flat surface that is ready to accept stain or coatings. Their shortcomings are well known. Orbital sanders can leave swirls and excessive polishing.
Orbital sanders use two types of movements simultaneously to product a random scratch pattern. The pad spins and orbits at the same time. The pad must spin and orbit to create the proper scratch pattern.
This is where the back up pad comes into play. The back up pad is the part of the sander that the sand paper attaches to, either hook and loop (H&L) or pressure sensitive adhesive (PSA).
For flat surfaces, this pad must remain in good condition and it must remain flat. When the operator tips up the sander to dig out defects on a surface, not only does this dig a divot in the work piece, but it also damages the outside diameter of the back up pad. Over time, the pad starts to retain the curve induced when the sander is tipped up and it no longer maintains a full 5& circle of contact on flat surfaces. The reduced surface area makes flat surface sanding take much longer and it induces much more swirls into the surface. It is also much easier to miss spots, leaving streaks of inconsistent surface finish.
The other back up pad defects that can really induce defects is an out-of-balance or out-of-square back up pad. If you sand a flat surface and you feel the sander pulling back and forth across the surface of the wood, the back up pad needs to be replaced. If you feel the sander bouncing as the pad rotates, then you most likely need a new back up pad. The PSA disks are often harder to remove from old worn out pads, as shown by the amount of PSA adhesive that remains stuck to it. The H&L disks will fly off of the back up pad when worn out. An out-of-balance pad will put undue stress on the bearings as well as the body of the operator.
Back up pads usually need to be changed out once a month in high production shops and on machines run several hours a day. In lower production environments they will often need changed once every 3 to 6 months. These pads are very low cost and responsible for doing the most important job in almost every wood working shop around the country. A new back up pad is far, far less expensive than reworking entire jobs with swirls and inconsistency.
Adam West
SurfPrep Abrasives Specialist
