Wood NetWork
Coating for Boards and Bowls
12/31/20
howard Member
Website: http://woodcontours.net
Greetings,
I have been using a commercial blend of mineral oil and wax but it is getting expensive and I am making a higher volume of these so it makes more sense to make it myself. I bought a large amount of mineral oil and ordered a 5lb block of beeswax from Beeswax Co. First, is the proportion 4 parts oil to 1 part wax? I have also heard of using coconut oil instead of wax? Lastly, the beeswax company said they do not "ultrafilter", their words, the wax, any need to run this through a fine mesh? Thanks for your help. Howard
1/8/21       #2: Coating for Boards and Bowls ...
We run an oil/wax mix on strip laminate and butcher block countertops on occasion. We by default run 6:1 on the oil/wax but if they are going to sit longer prior to use we will up the wax. Neither lasts very long and moreover just gives a bling factor when people see them.
No idea on the filtering. We burn the wax/oil in with a thick foam cross hatched pad on a 6" RO/Angle polisher. We burn it in til it pretty much wont take any more material. The sheen/finish will hold for weeks without use.
Even supplying material to rejuvenate down the line it never happens for us. No one does it. The natural fats and oils in use, soaps, etc. is all they ever see from that point forward but supplying a bottle of the salve is a good way to get yourself out of a callback.
2/25/21       #3: Coating for Boards and Bowls ...
Dave Edgerton  Member
We do an oil wax finish as well but I wpould not go with any vegetable oils whatsoever. Maybe linseed oil as it is a drying oil but boiled need is not food grade due to drying agent.
    Excel Wood Products
