Wood NetWork
Holz-Her FK1243
12/5/21
Michael Member
Hi, I recently became the owner of a used Holz-Her FK1243. I was told it was purchased new between 15-20 years ago. The original owner had the small scoring blade removed, (and now I know why). My problem is in the small scoring blade. It’s extremely difficult to raise and lower. I’ve tried just about everything short of taking it completely apart. The force required is much greater than the knob can handle, meaning the knob spins. However, I have been able to move it by hand.
Pictures of the saw are attached. The pictures of the undercarriage show the blade tilted to 45 degrees. There’s more room created in this position. The red arrow is pointing to the scoring blade, cables attached to the cam that is extremely hard to move. Any insight would be greatly appreciated. Thank you, Mike
View higher quality, full size image (959 X 1280)
12/10/21       #3: Holz-Her FK1243 ...
I think you need to flood the barrel with penetrating oil and then work it free. Dribble the oil into the two holes in the top of the casting. A more extreme option if that doesn't break it free is to apply heat first with a heat gun then with a torch if all else fails.
The photos show a lot of slack in the cable which you can adjust so that the lever will have less free movement before actually moving the scoring setup. But that is something to do after getting the barrel moving.
You may have to knock the mechanism out an do a cleaning and deburring and while you are at it change the bearings.
12/11/21       #4: Holz-Her FK1243 ...
I took a closer look at the photos. I think the most difficulty you are having is the slack in the cable. There are threaded barrel adjusters that can fine tune the cable but you will need to take up more slack than they can so you will have to find the cable clamp and pull the cable tight there.
    Excel Wood Products
    • American Vision Cabinets
    • Denray Machine
    • Lockdowel, Inc.
    • INNERGY
    • Original Saw Company
      Industrial Radial Arm Saws
    • CP Adhesives
    • Salice America Inc.
