Wood NetWork
Control voltage
5/1/22
Lance
Website: http://Furnitureconceptsinc. Com
All of a sudden control voltage wont work when we push switch/button
Homag sawtech. Chf-325
5/11/22       #2: Control voltage ...
Rob Young  Member
Of course you need to check the E-stop circuit. You should also check the Control voltage stop switch. If it fails and is in the open position it is the same as you pushing it manually. Control voltage won't work.
There is also possible there is a safety module that is reliant on inputs to properly operate. Without those inputs in a circuit like this the safety module will generate an e-stop condition. ~Rob
    Excel Wood Products
