Wood NetWork
Holzher 1265 panel saw trouble shooting
12/17/22
Frankie Member
1265 holzher panel saw. Saw works in horizontal position but when swivel head back to vertcle cut position it will not turn on
12/17/22       #2: Holzher 1265 panel saw trouble shoo ...
dustin orth
Sounds like you have bad wiring going into the saw head and the tension of rotating either makes or breaks the contact.
12/23/22       #3: Holzher 1265 panel saw trouble shoo ...
Jon Member
The saw will not run with the head swiveled in the vertical position unless it is locked into one of the vertical cutting positions. It is likely the switches or wires of that interlocking switch that is not working properly.
    Excel Wood Products
    • J&P Machines
    • CabMaster Software
    • Lignomat
