Wood NetWork
woodwork machinery Grease & Lubrication
2/10/23
Mathias  Member
Website: Woodworkfranzreb.com
Hello,
I need help to understand and to find the right lubricants and grease for several machines. I am a woodworker for 14 years now and own my business since 3 years. I newer was involved in lubrication or greasing the machines I used. Is there a grease/Lubricant what I can use on all the machines?
If yes what type, brand can I use.
What are you using on your machines?
Machines I have and need lubrication:
- SCMI T110i Shaper
- SCMI F410n Jointer
- SCMI s520 Planer
- SCMI Nova Si400 sliding table saw
- SCM Sandya 1s
SCMI K201 edgebander ( have here a 5 gallon bucket high temp grease, but manual asks for several different lubricants on different positions)
I have all the manuals of the machines and there are listed different greases and lubricants. I tried to look up all of the listed greases and lubricants but cant find them online. SCM is no help either. I had before several questions about adjustment for the table saw and they are not responding. That's why I am reaching out here for help.
Listed Greases/Lubricants in manual Nova SI400 and T110i
Agip GR MUEP1
Aral Aralub HL1
BP Grease LTX1
Shell Super grease EP1
Mobil Mobilplex46
Klueber Centoplex 1
Esso Beacon EP0
Multiple manuals listing the Mobilplex46 grease and I thought I can use this but I can not find anything about it in the internet.
Why would they list all these greases/Lubricants when I cant buy them.
I am located in Atlanta, Georgia.
Thank you for any help.
Mathias
2/16/23       #2: woodwork machinery Grease & Lub ...
Most of those greases are obsolete and superceded by a new name. You can find charts for the new alternatives for some of those greases. For the most part what you are looking for is a NLGI 2 grease (thickness) with a lithium thickener and for medium to high speed. With the exception of the glue pot grease which you already have.
Your tools do not need extreme grease performance so any bearing grease added on a regular basis will be sufficient for your lifetime. I am using SKF LGHB 2 on everything in the shop.
2/21/23       #3: woodwork machinery Grease & Lub ...
Mathias  Member
Hello Tom,
Thank you for you answer to my question. And also mention what you are using. I was looking for that.
I will keep doing reasearch to find a chart of the new names. Interesting part is that the table saw is build in 2017 and they still list the mobilplex46 in there manual.
12/21/23       #4: woodwork machinery Grease & Lub ...
Bergen Furniture & Design
Website: https://www.bergenfurniturenj.com/
Hi there! It's great that you're proactive about machine maintenance. For your machines, you might consider a versatile lubricant like Mobil 1 Synthetic Grease or Super Lube Synthetic Grease. These are high-quality options suitable for various applications, ensuring smoother operations.
    Excel Wood Products
    • O'Shea Lumber Company
      Merchants of Fine Woods
    • Original Saw Company
      Industrial Radial Arm Saws
    • GreCon
    • RT Machine Co.
