Subject: Re: 5 and 6" air sanders
8/17/22
door shop guy
What are you guys using for air sanders? I love my older Dynabrade Silver supreme but they stopped making them and now they have the extreme series. I bought one and it vibrates bad and in my opinion the design is not as good. Think i will get a Surf Prep 6" but they are out of stock. Wonder about the 3m. I use mine on a downdraft machine and i also use Mirka Ceros, and Deros 5 and 6" electric.
8/17/22       #2: 5 and 6" air sanders ...
All the air sanders I have are Airvantage, I really like them.
I have however been swayed by some of the great folks on this site to electric and my favourite now is the Mirka. I do really like the Surfprep 3x4 but have never used there 5 or 6 inch so can’t comment on them.
8/17/22       #3: 5 and 6" air sanders ...
Justin Member
We have an airvantage 5 inch electric sander it has a laggy start up, Also when sanding continuous it gets hot after about an hour beeps and shuts off I wouldn't recommend them if you are gonna be using it all day.We were use to the 3m air sander they are really nice just take a bit of air. We would really like to try the Mirka electric sander in a 5 inch. We have the Mirka finish sander and really like that.
8/17/22       #4: 5 and 6" air sanders ...
door shop guy
The Mirka Deros are amazing...just received the 6"..already had the 5"
Mirka customer service is the best i have ever received too.
I found some of the old stock Dynabrade silver supreme sanders and loaded up on 3 of them. They run smooth as butter. They have been discontinued for quite some time is what i was told.
8/17/22       #5: 5 and 6" air sanders ...
Mirka Ceros here. Wouldn't go any other way. Deros is bigger and more clumsy, but still works as well.
8/17/22       #6: 5 and 6" air sanders ...
door shop guy
I thought the same thing about the Deros too but i actually prefer it more after i used it. It just looks clumsy. I have had my Ceros in the shop 5 different times for repair now and they take care of me every time on it.
8/17/22       #7: 5 and 6" air sanders ...
Mirka Ceros here as well and two Air Vantage electrics. To the post that says they overheat and turn off.. your operators are making the cardinal mistake of bearing down on the sander. I have an employee who constantly has to be reminded that you dont bear down on a sander. They sand better/faster with pretty much zero pressure (faster pad speed/no bogging). Its understood that other electrics dont have this protection but companies like Festool have been endlessly trying to educate owners not to bog/bear down on sanders for years with the sharpie on the pad protocol.
I have a 5" and 6" Airvantage electric and two Mirka Ceros and the biggest nuisance with the Airvantage for us is the fact that it times out on non-use and having to hit the up button on the sander to wake it up after 5 minutes of sitting. I understand the logic there but it'd be nice to be able to shut it off.
Ive sanded with the Airvantage sanders for 10 hours a day and never once had one cut off on overheat. I will say they get warmer than the Mirka's but Ive never had one cut off. Now... put the exact same sander in the hands of "impatient Arthur" who refuses to stop bearing down on the sander and tipping it on edge to dig out a defect, and he will trip that sander on overheat in 5 minutes.
In my world the overheat cutoff is a bit of a blessing because it lets me know who to take off the sanding station ASAP.
8/17/22       #8: 5 and 6" air sanders ...
I only have the air powered air vantage sanders, I have the dust collection hoses on them and they are fantastic sanders, If you have compressors that are running all day with lots of air I would use the air sanders all the time. However I am small so running the big compressor all the time is more expensive than the Mirka’s, also the electrics are easy to use anywhere as far as site work goes.
8/18/22       #9: 5 and 6" air sanders ...
Well covered topic on air/vs electric but whether your making a ton of air or not, every CFM of manufactured air has a cost, and a very high cost, whether you making miles of air or only a little air. An air sander consumes the air (more actually) the capacity of a 5HP compressor, plus dryer, plus filters, etc.. So whether your a massive shop or a one man show every time you hit the paddle on the sander you can imagine a 5HP motor, and then some, coming out of your bank account. Its just that simple.
8/23/22       #10: 5 and 6" air sanders ...
door shop guy
Yesterday i got out my Ceros..Its been maybe a year since its last repair and i hadnt used it because i have been using the Deros. WOW!! Its uncomfortable and does not have a brake compared to the Deros. I guess i will keep it but i will not use it again just because the Deros is so much nicer.
What vacuums are you guys using on your sanders? I use the old Fein Turbo 2 and am getting a new one of those as well. Would you get the HEPA version?
8/23/22       #11: 5 and 6" air sanders ...
I disagree. The Ceros is slightly smaller than a Dynabrade. I guess it's personal preference.
    • Impact Search and Placement
    • ECabinet Systems
    • Better Vacuum Cups, Inc.
    • Doucet Machineries Inc.
    • Forestry.com
