Subject: Re: Moving a sliding table saw
1/9/20
tom ruth Member
I'm thinking about getting a used sliding table saw. (8' slider or so) Just wondering the best way to move it and how much to take apart?
1/9/20       #2: Moving a sliding table saw ...
For an 8' I would just remove the wagon and swing the outrigger against the saw and not disassemble anything if you have forklift at both locations. You'll likely want to dial it in in it's new location but in my opinion the less you can take apart the better off you are. If it has to be handled without forklift I would just rent one.
1/9/20       #3: Moving a sliding table saw ...
Tom C
Made it's own Custom Skid,Pallet jack , Winched on to flat bed towing truck...
View higher quality, full size image (512 X 384)
1/9/20       #4: Moving a sliding table saw ...
Bill Member
I agree with what Tom said.
1/9/20       #5: Moving a sliding table saw ...
Tom Ruth Member
Thank you Mark B, Tom C and Bill for the comments and ideas. Tom C, that looks like a big move.
1/11/20       #6: Moving a sliding table saw ...
Ken Member
I moved an Altendorf myself. On the leaving end we put it on a pallet on a tilt trailer. I was able to use a pallet jack to roll it off (used a strap to keep it from running away). Transporting it I removed the right side and end extension tables but not the slider. I believe I read somewhere to wedge tapered wood wedges between the sliding table and bed to lift it up slightly to prevent it from bouncing up and down and damaging the bed rollers or ways. Of course I read this after I moved it but all seems fine.
5/4/22       #7: Moving a sliding table saw ...
BK Member
about to move my own slider (if all goes well with the negotiations) and wanted to thank you for asking the question Tom & and to you Tom for giving me the perfect solution with the prefab'ed pallet skid. Will surely beat my existing plan of straps and crossed fingers. Cheers!
10/16/22       #8: Moving a sliding table saw ...
Sean Kovacs  Member
Remove the slider for sure and put in on a long skid (two nailed together. line the skid with wrapping foam and lay it down table side DOWN, this way any road bounce wont affect the carriage bearings as badly.
    • Country Saw & Knife
    • American Fabric Filter Co.
    • Denray Machine
    • Biesse America
    • Impact Search and Placement
    • Charles G.G. Schmidt Co.
