Subject: Re: Surface under gas range cooktop
6/7/23
Corey Green Member
Building a kitchen and may have a simple question. Installing a gas range commercial style cooktop and says non-combustible material under unit, what materials do you use for that surface? Do you apply an insulation blanket of some sort or a fire rated plywood? Thanks for any info.
6/7/23       #2: Surface under gas range cooktop ...
That's a new one. Haven't come across that yet. That's weird.
I'd have somebody just bend up a thin gauge tray.
6/8/23       #3: Surface under gas range cooktop ...
mike
if you have to follow city codes .
most commercial products are not appoved
for city codes. so i would check with inspector 1st.
6/10/23       #4: Surface under gas range cooktop ...
Andy Ryals  Member
Many MDF producers offer fire retardant panels.
6/10/23       #5: Surface under gas range cooktop ...
Joseph Christman  Member
Website: RowlaStudios.com
Many manufacturers produce a metal liner for underneath their cooktops/grilles, usually with built-in spacers for mounting the unit. If your cooktop doesn't, just design something with a bottom/sides and have it fabricated in stainless.
    • Better Vacuum Cups, Inc.
    • Biesse America
    • CP Adhesives
    • Impact Search and Placement
    • Template Services
