Subject: Re: Edgebanding glues: EVA vs Polyolefin
10/28/23
Oggie  Member
I recently ran into a problem with my usual EVA glue—it just wouldn't stick to this one particular PVC edgebanding tape. So, I ordered a tape from a different manufacturer that matches the color, and I'm hoping it will do the trick when it arrives next week, but remains to be seen.
Right now, I'm not sure if the original tape was defective because it wasn't primed properly, or if it just didn't get along with my glue. I did some research, and it seems like stuff like this happens quite often, where the glue and tape don't play nice, even if neither of them is faulty.
In this particular case, the manufacturer of the PVC tape and board itself uses PUR glue for edge banding in their own production line, so maybe the tape in question was not primed at all, since PUR does not necessarily require primed tape (according to my google research).
I've been thinking, maybe switching to polyolefin glue could be a better option than sticking with EVA. My main goal is to avoid constantly switching between different glues and find one that works for most things. The problem is, there's not a lot of info out there about polyolefin glue.
So the questions:
1. Jowat 221 is one of the options suggested, but I'm curious if anyone here has any hands-on experience with it, or for that matter, any polyolefin glue?
2. What would be the pros and cons of polyolefin with regards to EVA?
3. Is there a way I could successfully apply primer to the unprimed PVC tape in some DIY fashion?
Thank you!
11/2/23       #4: Edgebanding glues: EVA vs Polyolefi ...
Bozzy Member
I almost asked the same question 3 weeks ago when we were getting ready to make the switch because I couldn't find anything on here about the PO. We have started using Jowat 237.5 unfilled PO glue and it seems to be going well so far. We've only used it with a walnut color laminate and can't tell right now if the glue line is thinner than EVA. One thing that I like is that we run it at 200C and it doesn't burn.
What I've been told about PO is that it sticks better than EVA and that it has better moisture resistance. The cost for us is about 50% more per bag than Jowat unfilled EVA, but if the performance is marginally better than EVA, I think it would be worth it. Will update once we have more experience
11/6/23       #5: Edgebanding glues: EVA vs Polyolefi ...
Oggie  Member
Thank you Bozzy.
I want to give it a try but can't find anyone who sells 237.50.
Guess I'll have to call Jowat directly tomorrow and see about that.
Where did you get yours (if you are in the US)?
11/6/23       #6: Edgebanding glues: EVA vs Polyolefi ...
Bozzy Member
I'm in Vancouver, Canada. I got it from Mckilican International. I would not use the Jowat 221 because it's not meant for edgebanding, but for wrapping.
We had bit of an issue when we started edganding 1" laminated plywood with PO last week. The tape wasn't sticking very well. I think the premill on our edgebander is getting a bit dull and was pulling some of the fibers out of the plywood that was perpendicular to premill and not allowing the glue to fully apply to the panel. This wasn't an issue with EVA because it's thicker than PO. We increased the the glue dosage from Dose 1 to Dose 2 and now the tape sticks perfectly. Need pliers to pull it off.
11/8/23       #7: Edgebanding glues: EVA vs Polyolefi ...
Oggie  Member
Took me almost a whole day to find out who has it in US.
Anyway, that 237.50 glue seems to be fairly new product on the market.
We should get it in a few days, I'm very eager to try it.
    • ECabinet Systems
    • Anver Corporation
    • American Fabric Filter Co.
    • Charles G.G. Schmidt Co.
