Subject: Re: Vertical Panel Saw tearout
6/25/24
Kurt Member
I am considering adding a used Holtzher 1265 supercut to the shop but would have to eliminate a sliding table saw due to space confinements. I only use prefinished plywood for my boxes and I am concerned with cut quality. I do not have premill on my EB. I know the supercut has scoring knives but concerned it wont match or exceed a scoring blade on the horizontal slider? Any advice or experience?
Thanks!
-Kurt.
6/26/24       #2: Vertical Panel Saw tearout ...
Jim Herron
Can't comment on the Holz Her but I have an 88 Striebig Standard that uses single blade scoring with main blade as a climb cut, through on down cut.
Cuts very clean, especially with fresh blade. I don't know if climb cut is possible on the HH
Replaced an SCMI slider with the vertical and wouldn't consider going back.
I have dedicated 8020 jigs to production cut common angle cuts like 45 degree angled cabinets. The very occassional oddball cuts are quick and clean with the track saw
6/27/24       #3: Vertical Panel Saw tearout ...
Bruce H
Change your space and keep the slide saw. You will find both very useful for different things. I have an Altendorf and a Striebig. Hard to eliminate one or the other.
    • ECabinet Systems
    • Anver Corporation
    • American Fabric Filter Co.
    • Charles G.G. Schmidt Co.
