Subject: Re: Reeded doors
Reeded doors
2/12/25
Nathan Member
Looking for recommendations on how do build a reed door. We have a customer wanting reeded doors that do not have frame around them. Thinking of cutting a 3/4 veneer door that is edgebanded on the edges and the laminate 1/4 solid on the face. Then run a cnc program to rčed the solid on the face of the panel. Open to any suggestions.
2/13/25       #2: Reeded doors ...
John McGinnis Member
Try using a slab door and laminate this material on the face:
https://dilegnopanels.com/products/flexible-mdf-board-embossed-wood-pulp-finish-d092
2/13/25       #3: Reeded doors ...
My first thought was that once you laminate the 1/4" to one face, the door would begin to warp drastically.
My second thought is that this might work just fine. I would laminate with PU glue so that I don't add moisture. Routing the reeds will cut all the way through the solid so it will nullify the risk of an unbalanced assembly.
Do samples all the way through to finishing to avoid costly surprises.
2/13/25       #4: Reeded doors ...
duster
I've done these a few times with good results and no callbacks. We glue up solid panels that finish at 7/8" thickness. Milled the reeds, and screwed 3/4" thick x 1.25 wide cleats on the back of the doors. I counterbore the back side of the cleats about 3/8 deep to allow the door panels to expand & contract a bit with humidity changes. I wasn't sure if it would work, but we rolled the dice and it did.
Sorry, I don't have a photo.
2/20/25       #5: Reeded doors ...
Chris
Website: Tomasi.us
I just spoke with white river yesterday and they have premade 1/4" thick solid 24x46" reeded and other profiles. See pics.
I'm suspicious though. Personally, I don't understand how you can glue a panel to one side of a substrate and expect it to not warp, or the solid reeded to not crack when it tries to expand.
We've glued tambour to parts that aren't doors, but that's it. I get Instagram pics of this from designers and ask myself if it looks good on a pic and then self implodes a week later or ??? Milling reeds in HDF for paint grade could work, but then, wouldn't the panel be unbalanced again as well?? I'm curious how people achieve this with doors.
    • Wood Doctor's Rx, LLC
    • J&P Machines
    • Lignomat
    • Steve H. Wall Lumber Co.
    • Forestry.com
    • Country Saw and Knife
    • The Millwork Studio
